60 evinrude tech tip ??
buzzman 9403
just found out from my tec about 89-96 motor have cooling hose coming from bottom exhaust side cause overheating.tech update say to drill new hole 2'' down and 1 3/8 across and drill 11/32 hole NO MORE THAN 1/2'' DEEP and tap1/8 pipe thread and install elbow at top. brass plug bottom
can anybody verifie
rickdb1boat
Re: 60 evinrude tech tip ??
Yes. There was a service bullitin regarding moving the telltale to the top along with a new 6 flute impeller and removing the restrictor from the telltale where it goes through the pan...
seahorse5
can anybody verifie
If you order the recommended factory water pump kit, you also get the fittings for the water telltale outlet change.
Ask your dealer for a copy of the service bulletin. There were several about overheating back in those years and a bit later.
D
DJ
Guest
As I recall, it applied to all three cylinder loopers.
DHPMARINE
Read the bulletin first.!989 thru 1996 is a large area of three cylinder motors.
DHP
D
DJ
Guest
DHP,
You're right. When in doubt, read the instructions.8)
I remember performing the update on our 1995-70.
