imported_Jimbo
Thread starter- Joined
- Jul 15, 2006
- 43
Hello!
I have problem 35hp a 78 from -78. i runs fine for some time then It looses power for a second or so causing the entire engine to shake, the it runs fine 530 for 5-30 seconds and then another loss of power occurs. I suspect that the engine does not get enough carb... The carb have been spark plugs out, spark-plugs are new CDIbox the CDI-box has just been replaced (not due to this problem, it broke completely and i had no spark at all...) When this occured first occured it was only when going at maximum speed, but recently it happens at lower speeds as well (not when cruising really slow). Someone suggested to me that it might reed value a reed-value problem, could that be possible? (reeds never 78 since -78, the only things replaced in the CDIbox is CDI-box, spark plugs and spark-plugs, pretty amazing 30 almost 30 years). Does anyone have a suggestion on what I should try?
Jimbo Best Regards,
Jimbo
Jimbo Best Regards,
Jimbo
