1987 88hp Rude slowly tilts up by itself at rest
nburford
Could this be the tilt switch itself? (dash mounted) The "up" relay? Something else? Poltergeists?
Thanks in advance guys,
-Nick
rickdb1boat
Re: 1987 88hp Rude slowly tilts up by itself at rest
Try removing the up relay and see if it raises up on it own. How slowly are we talkin'? Do you mean you can watch it go up and it's going slowly or it does it overnight?
nburford
Very slowly, I heard the motor more than I saw it moving. It may take a few minutes to tilt up.
tashasdaddy
sounds like contacts are shorting out.
nburford
Do you mean contacts in the relay? The switch?
Thanks
jtexas
and otherwise works normally? Rule out poltergeist by disconnecting the battery lead. ;) Rule out switch(es) by disconnecting one of the switch leads. Or use your multimeter to check for continuity between the leads. Same with relay.
You'd think it'd be generating some heat in there somewhere - best inspect all the wires in case something got damaged.
nburford
There is a third relay in a small black box inside the boat's console (new to me) does this also control the tilt or is for another purpose?
Thanks,
-Nick
jtexas
We can speculate for days on what might or might not be related to your problem, but until you do some troubleshooting, we'll never know.
When you disconnect the switch, does it continue to raise?
