Alan Serven
Thread starter- Joined
- Jul 4, 2006
- 10
Engine/system: 1994 OMC 175 HP 60-degree V-6
Question: Does anyone know how to check whether the sensor in the oil resevoir is good or bad? I get a continuous warning horn as soon as I turn the key to "run" and disconnecting the oil level sensor (or the horn itself) is the only thing that makes it stop. (Disconnecting the high temp warning sensors and the fuel restriction (vacuum) switch have no effect.)
I have checked the resistance across the leads with the sensor installed and am reading about 2100 ohms.
I hate to just have to go buy one and swap it out to see if that really is the problem.
Alan
Alan
