miichael18
Thread starter- Joined
- Mar 24, 2004
- 161
I have a 1974 70HP evinrude and i bought a tach and put on it and at wide open throttle it tachs 5600RPM. Reason i Purchased a tach was because i am in need of a new propeller. Mine is aluminum and is in very rough shape. Is taching 5600 rpm fine for this motor or should i try to get a different size/type of prop? I was going to just change the prop to a stainless steel same pitch and diameter but i wasnt sure what my wot rpms was. Right now the boat run 29mph on water if i add a stainless steel prop with the same pitch and diameter will it increase my speed? or should i just go with another aluminum?
