Will a Ballistis SS prop from a Suzuki fit a Merc?
Wiggy
I've spotted a cheap Ballistic SS prop that was on a '98 Suzuki 55hp. The diameter and pitch are perfect for my motor but will the prop fit on the prop shaft? My motor has 10 splines, but how many does a Suzuki have?
walleyehed
Re: Will a Ballistis SS prop from a Suzuki fit a Merc?
The Zuki of that size has 13...you're gonna have to find a prop FOR your application.<br />If you buy a cheap prop, then buy a 38 $ thrust washer to make it work because it's from a different engine, it "may" end up costing you more...
Texasmark
Why don't you contact Michigan Wheel and ask them, or go to their site and once you download their 2.??? Mbit PDF file you can see for yourself. If a special thrust washer is required for an application, they list it.<br /><br />Mark
walleyehed
The spline count is completely wrong, Mark....as is the length of the inner hub.<br />I've got some zuki props and have found how to make them fit my 70HP Merc....set them aside and buy the right ones...
Wiggy
I've just found out that Suzuki has 13 splines and mercury 10, so it ain't gonna fit.<br /><br />I'll get the right tool for the job I think.
Texasmark
10-4 Ken. Looks like Wiggy solved the problem himself.<br /><br />Mark
walleyehed
4 posts above....<br />By walleyehed;<br />
.<br />maybe I wasn't clear.... :D
Dhadley
Wiggy, what prop are you looking for?
Wiggy
A SS 10 3/8 or there abouts 13p 10 spline....
