Re: Looking for suggestions
Well, at this time I have 3 props, the 24 Raker, a 21 stainless (no brand, but numbers are 389923 14¼ x21) and the 20 quicksilver 4 blade. The 21 stainless is fine for skiing but slips badly at boarding speed. The 24 is to slow out of the hole. Switching props would mean this would happen a dozen or so times through the day, a little tedious to say the least. Typically we can survive with the quicksilver as it does hang on fairly well for boarding and is very nice to ski and bare foot with. So I'm smiling at the thought of the Turbo and a jack plate. A 22 might work if the smart tabs can bring the bow down faster, thus getting me out of the water quickly. If so than the 22 may be ok for skiing and should be better than the quicksilver for boarding. If all this holds water with you guys than I'm still smiling at the prospect of making a good thing great! Q. Does the Turbo prop come with vents, if not can it be modified to add them?<br /><br />So which plate is the next question, seems there are a few to choose from and I would only consider a hydraulic set up. My engine is already at its lowest possible height as the mounting casting is already sitting on the top of the transom and I have hydraulic steering and its hardware would necessitate a set back of around 9 inches before I can get the engine any lower, I guess the other option is to fit a longer leg (and I have thought about that option also) <br /><br />If fair to say that so far all that we have discussed I have had in the back of my mind for a while, problem is the hit and miss of experimentation can be very expensive and has always just kept it in my head! With the help from this forum Im hoping to avoid a lot of the misses and achieve more hits.<br /><br />Thanks to all who have so far contributed.
