Re: 4 blade props
have a 285hp v-8 in a 1976 24' deep-v formula, merc alpha drive with 1.5 ratio. The standard 14x19 3-blade is what I used to run, boat would do around 45mph wot. I have a stilleto 4-blade 14.25x20 prop, which gets me about 4400-4500 rpm at around 45mph. I ended up buying 2 props, a 14x18 and a 14x20, trying both and returning one. It was a huge difference, the 18" prop would take off great but at 3000 rpm my cruise speed was 25mph or less. With the 20" prop, not as great acceleration but cruise was much more comfortable at 30mph at 3000 rpm.<br /><br />4 blades always get more bite, so you can hopefully expect a little better cruise speed when heavily loaded. Top speed can suffer a little but it's so little you won't notice, not like you run full throttle all the time. They are also smoother, less vibration, at least on mine vs a 3-blade aluminum.
