Jeep cherokee
Ron G
We have a cherokee at work here,I think the switch went bad,tested battery good,jumped off from the starter and it started so i put a new starter in it,still wont start,waited till afternoon and it started?? the next day wouldnt start.when ya turn the key the radio and lights come on,any ideas ?is the switch or is there a little plunger some were on the column??
dolluper
Re: Jeep cherokee
Check the fusible link at starter solinoid large nut,looks like wire but it's not,run your fingers along it feel for a break inside casing,or where it connects to main harness they corroate there
Ron G
Re: Jeep cherokee
I put a new starter on it.wires all looked good.
Johnson110
Re: Jeep cherokee
CPS switch bad maybe, crankcase position switch located on driver side of bell housing, if it is a 4.0 motor, it is a pain in *** to replace but do-able with a 1/4 socket drive can get at it from under truck, assuming starter is good and cranking 1 hope this helps
Ron G
Re: Jeep cherokee
Thanks guys it is a 4.0,I think ill send on to motor pool Ive never done it and dont have time to do it,I thought it might be a pain *** .
ZmOz
Re: Jeep cherokee
Sounds like the neutral start switch. Try putting it in neutral.
Ron G
Re: Jeep cherokee
Did that ZMOZ one of the first things i checked.what else would cold weather affect??
ZmOz
Re: Jeep cherokee
Does it just not turn over but the lights and stuff works? If that's the case there's a 99% chance it's the neutral start switch. Mine stops sometimes in neutral or park. Move the shifter back and forth like 10 times and make sure it really clicks into gear and try it. I had to wire a switch around mine.
Ron G
Re: Jeep cherokee
lights work with key on,is the swich up under the shifter?and what did ya do to bypass it?
Ron G
Re: Jeep cherokee
Thanks Zmoz, ill check that out on monday.I think that may just be the culprit.
Skinnywater
Re: Jeep cherokee
We don't have a model year.<br />The later models have a PDC (Power Distribution Center) with all the fused circuits and the starter relay.<br /><br />Might want to get real basic.....check your battery cables and ground connection.<br /><br />Any neutral safety switch location is model year dependent also.
Ron G
Re: Jeep cherokee
I think it maybe a 93 its awork vehicle bought at auction 7 years ago its pretty raged out.but that 4.0 is strong as an a ox still,
Ron G
Re: Jeep cherokee
Okay this is crazy, the past 4 times i tried to start nothing,dash lights came on and radio,wait 4 hrs with it sitting in the sun and it starts wright up.
ZmOz
Re: Jeep cherokee
Originally posted by Ron G:<br /> Okay this is crazy, the past 4 times i tried to start nothing,dash lights came on and radio,wait 4 hrs with it sitting in the sun and it starts wright up.
Even more proof it's the NSS. It will come and go completely randomly. Mine usually won't restart if I stop for something quickly - like gas. Sometimes it will refuse to start at all for days. Sometimes it goes weeks without ever having a problem. My old Cherokee did something similar too. I like having a button rather than trying to clean/replace the NSS because it works kind of like a kill switch. Plus it's less work. :)
Ron G
Re: Jeep cherokee
So ZMOZ you just bypass the nss altogeather?ran a wire from the batery to a switch and then down to the solinoid??what size wire did you use 18??
dolluper
Re: Jeep cherokee
Pull the connector off the switch [NSS] and jump the leads of the connector with a paper clip or wire,But BEWARE it will start in any gear
SpinnerBait_Nut
Re: Jeep cherokee
The NSS is on the side of the tranny if this is an automatic and the grease gets dried up in there and the contacts get fried, crudded up and lose connection and that is why it sometimes starts and sometimes don't.<br />Could also explain why it will start after it gets warm out.<br />Just enough heat to let the contacts penetrate through the old grease.
ZmOz
Re: Jeep cherokee
Originally posted by Ron G:<br /> So ZMOZ you just bypass the nss altogeather?ran a wire from the batery to a switch and then down to the solinoid??what size wire did you use 18??
Yep. I think I used 16 gauge. Whenever you push the button the starter turns over.<br /><br />I used a big red button that says "EJECT". You wouldn't believe how many people believe it and get scared when I push it and it starts making noise. :D
Ron G
Re: Jeep cherokee
Thats cool zm,SBN it is an automatic and i told my boss i could fix it for little to nothing,he said he wanted it carried to the dealer,i was like fine then,i can barly wait to see the invoice on that.budget being tight and all. :rolleyes:Thanks guys for all the help.
