bosun type help needed
rbigg
Got a long, 2" wide nylon tow strap someone formed an eye in one end of by<br />doubling the strap and knotting. A subsequent pull has left a mamoo tough<br />knot.....one with a set to it.<br /><br />I sat down and tried to pick the knot with an ice pick, trying to get any<br />kind of slack, anywhere in it. After all my finagling, I couldn't get<br />anywhere at all without piercing or tearing the strap material.<br /><br />Can anyone offer me any further tips or tricks so I can salvage the strap<br />intact?<br /><br />If not, what I guess I'll do is simply cut out the knot part and take the<br />remaining two pieces to a shoe shop and get 'em lapped and sewn across in a<br />number of places. That way I'll have a 25% shorter tow strap, but still<br />good to go.
Drowned Rat
Re: bosun type help needed
rbigg. 1st try soaking the strap in water for about an hour. Then pick up the knot and roll it between your hands applying as much pressure as possible. If that doesn't completely break the knot, you should now be able to use a marlin spike (ice pick with a rounded end) to get it out. Good luck.
Terry H
I've never been able to get those knots out. You could use real soapy water to soak...I'd be interested inknoweng if you are successful...Chief :)
Drowned Rat
Depending on how much of a load it sustained, the synthetic fibers may have melted and fused together in which case you will never get it out.
llfish
You will probable loose some strength if you have it sewn-up.
