Re: tohatsu idle adjustment?
My suggestion would be not to adjust it at all. 2 stroke idle is fickle. Every time you buy gas and mix it, no matter how carefully - it wil change. Randomly. (Its not you, the EPA has them constantly fiddling with the volatility and the Ethanol content for air quality and the Iowa caucus respectively.) When the weather changes, it will change. faster hot, slower cold. If for some reason you can't ignore it, only change the idle stop, not the mixture, and don't "make it right" just bring it back far enough to live with it. Otherwise your next tank of gas may have your motor sputtering and dying all the time. When you get a sense of the range of things through your whole operating season, you'll know if you still want to lower the idle.
