Re: 2003 Tohatsu Idle Problem?
I had that with my '96 40. It started after I leaned out the carbs a bit. I had the motor on a 17' Whaler and out in the ocean, when heading with the swell, that "noise" would occur. I could not get any of the local service dealers to confirm this unless I paid them $75 and hour to go fishing with me. I came to the following conclussion: When going with the swell, the effect of the wave is more pronounced because the duration of it's effect on the boat is longer. As the swell approached the transom, it caused the boat to "surf", relieving some, if not all of the load from the prop. This created a lean condition. At troll speed, a lean condition will not cause damage to the engine such as it would at high speeds in the case of a plugged or undersized jet. The worst case scinario would be that the engine would die, and then you would need to start it back up. At first I thought it was due to a rich condition, causeing the engine to load up, but I have found that that was not the case. I repowered to a 90 hp Nissan a few years ago and ran into the same problem. With the stock 17" pitch prop, I was able to get rid of the problem by richening up the pilot screws, but, the motor kicked alot with that setting. I then went to a smaller prop and solved the problem. The 40 hp had a 13" pitch prop. I have found that a 2-stroke will load up any time it is run for long periods of time at low rpm, even with an oil injection system. You need to run it closer to WOT (4000+) for 5-10 minutes in order to "un-load" it. After you troll for a while, never accelerate fast, but rather gently bring it up to speed, it may feel like it is missing a little, throttle down a bit until you feel her smooth out and pick up speed on it's own. I have found that the settings in the service manuals do not account for the new oxygenated fuels so though your setting may be per book specs, oxyginated fuel create a bit of a lean condition by their very nature so you may need to compensate a little. Make sure that the carbs are in sync. It is difficult to sync. the pilot screws according to the book procedure with just the standard RPM guage but it is possible. Good luck.
