I have a 1986 85 HP Force outboard, model 856X6L. Went to the lake for the first time this year, came right back. Checked the starter solenoid and found it to be bad, replaced it and here is what is still going on. Turn the key, press in to activate choke, nothing, solenoid attempts to set choke but will not. Turn the key to start, the starter solenoid will click and the starter turns but does not engage into the flywheel. <br /><br />I checked the circuits with a multi meter and getting 12 volts thru out the system, battery is freshly charged. <br /><br />Anything further to check/do before I but a new starter and choke solenoid???? SELOC manual is not very helpful............
