lennygilbert
Thread starter- Joined
- Aug 1, 2004
- 37
78 chrys-75hp.<br />running 17p Prop<br />Compression-150,151,150Psi.<br />Fuel mix-50:1<br />boat is 16ft loaded with 2 batt,trolling mtr,9gal gas,3 people at around 360lbs total.<br /><br />At wot i am getting only 2800rpms and running at 28mph(according to the gps) on board spedo only shows 20mph but i found a crack in the pito tube.<br />I pulled the plugs and the top and bottom are black and the center is clean.However the previous owner did say he replaced the plugs within the last two months and it hasnt been used that much.Prev owner also stated that he mixed the fule with more oil than what it called for just to be on the safe side..<br />Here are my thoughts on why the rpms and speed isnt there. <br />1. since the owner ran to uch oil,maybe the high speed jets are clogged??<br />2.the tach is off<br />3.needs to be decarboned<br /><br />Right now the plugs are NGK HBUW(i think).They are the flat bottom type.<br />What are the correct plugs to use?<br />This boat will mainly see medium to high speed,pulling tubes during the summer,I'll be useing the trolling mtr for fishing,<br />Thanks:
