New stator? Is this saftey wire? pics included
peacekeeper6
i was wondering if i need a new stator, this one has lots of rust and what looks like bubbles in the eposxy like stuff surrounding the coils. What are the bubbles that are in the epoxy stuff?
<br /><br />i was also wondering if you could tell me if this is the wire for the saftey switches and components. <br />
<br />all of this is on a 125 HP L drive thanx in advance!
scotiany
Re: New stator? Is this saftey wire? pics included
That might go to the nuetral interlock switch. Looks like the wire on my Chrysler that goes to the switch.
peacekeeper6
thats what i though, to disable it i have to just unhook it right?
peacekeeper6
anyone have any ideas on the grey bubbly stuff?
t.martin
My stator looks exactly like that. It works.
peacekeeper6
hum, that cant be good, the inside rings do they kinda like seperate?
peacekeeper6
the rings on the side are kinda like expanded away from each other does this affect performance?
peacekeeper6
after reviewing further i noticed the stator pads are worn more on some then the other. if the pads are worn too much will this cause no work?
Quick Cal
I'm by no mean's an electrical expert. But when I tried to test all my component's, the number's on my meter just went nut's, so I figured something was wrong somewhere. Now I'm not saying this is how all bad stator's will look, but it's how mine looked. It all stated from a loose connection on one of the wire's. Cal<br /><br /> http://community.webshots.com/photo/357815887/364660043GdJcWF
peacekeeper6
wow that is bad, mine isnt nearly that bad but i just noticed some of the pads are very worn so maybe that is my problem. i am hoping so as i got a new trigger and still have no spark.
