roastinears
Thread starter- Joined
- Aug 26, 2004
- 36
Howdy All!<br /><br />1982 or 1984 chrysler 75 hp model 758h2d serial # 1302<br />last summer motor was perfect. Put in water, crank with choke for 3 seconds, started and ran great all day. NOW. If I get her warmed up she runs great all day, but getting from a cold start to warm up is the problem. She will crank right at 3 seconds of choke, run idle (high idle) for about 45 seconds then stop. If I keep trying she may sputter but will not start anymore. I can pull the plugs (all three plugs are wet) and dry them off, crank the motor for a couple of seconds to clear the cylinders, replace the plugs and shell crank back up for 45 seconds and die (wet plugs). Here are the things I have done. Cleaned the carbs (soaked overnight in b-12), replaced the needle and seat, replaced the fuel pump. I have done exactly what the seloc manual says about rebuilds on float level. I have even set the float height (from gasket to float) to 16mm and the motor will not start ( but I can squirt fuel into the carbs and it will fire up) so Im pretty sure the needle and seat are working. I have set the idle speed screw just like the manual says and everything from ½ turn from full closed to 4 turns from full closed and pretty much the same thing happens. Wet plugs. I can always pull the plugs, clear the cylinders, wipe off the plugs and she fire back up. Can the recirculation path cause this kind of problem? Can I be missing something on all three carbs? Thanks in advance for the help.
