I'm new so please bear with me. I aquired a 45 hp and mounted it on a 14ft chrysler boat. It started and seemed to run ok till I put it in the water. Top rpm was 1200. after tinkering around rebuilding carbs, changing plugs, cleaning puddle valves, adjusting points, it ran a bit better with earmuffs hooked up but it kept flooding out the lower cylendar. And, raw feul/oil was running out the exhaust. Also, at ile, it surges about 200 rpm. I was told to look for an airleat around the carb, but that os fine, no leaks. I am about ready to toss it in the lake. Any ideas?
