Does a outboard motor have an alternator?
harrykleinsasser
I know this is a basic question but does my 85 hp 1986-1987? force outboard motor have an alternator? Thank you
rogerwa
Re: Does a outboard motor have an alternator?
Probably a stator which does a very similar thing. Look up under the flywheel and you will see coils. A magnet or magnets connected to the flywheel travel close to these coils and generate current. If I am not mistaken it generates AC that is passed through the rectifier which converts it to DC.<br /><br />Let me know if this is not right..
harrykleinsasser
Yes I do see coils does this stator actually charge the battery? Like a Car alternator. <br /><br />Thanks
rogerwa
It should.. The trigger is also under there if I am not mistaken. This is what signals the CDI and coil packs to fire..
DeFeet63
rogerwa, might I ask you a question related to the alternator in a 85 Force? Or should I make a new post? Thanks
wilkin250r
They work slightly differently, but the effect is the same.<br /><br />An alternator in a car spins a coil of wire in a stationary magnetic field, thus generating electricity.<br /><br />A stator is a stationary coil, and the flywheels spins magnets around it, thus generating electricty. A stator almost always has some sort of ignition trigger and ignition power source combined with it, so it generates electricity AND is an integral part of the ignition system. An alternator is not part of the ignition system.<br /><br />The stator produces AC current, which is then changed to DC through the rectifier. Most of the coils on the stator are for power generation to charge the battery and run the electrical system for the boat. A few of the coils are used to generate spark energy, and are usually separate from the other power generation coils. It is possible for a stator to malfunction and NOT re-charge the battery, yet still providing spark energy.
