wilkin250r
Thread starter- Joined
- Feb 9, 2003
- 570
In order to properly diagnose ignition problems, the manual calls for a "Peak Voltage Detector." However, most multi-meters only measure RMS voltage, and will not work. Peak Voltage detectors can be expensive for just a single use.<br /><br />Here's a quick little tip. You can make a peak voltage detector using a diode and a capacitor. Connect the diode and capacitor in series, and place them across the terminals you want to test. You can now read the PEAK voltage across the capacitor using your multimeter on a DC setting.<br /><br />Use a small ceramic capacitor, like .01uF, and make sure the voltage rating of the capacitor and diode exceed the voltage you're trying to test.<br /><br />Moderators: This could probably go in a more general section, as this probably isn't limited to just Force engines. Feel free to move it to the appropriate section.
