120 hp Force- busted skeg
stockhouse5
I have sheared the skeg on my motor. Can it be fixed or do i have to purchase an entire lower gear housing? Suggestions?
norman158
Re: 120 hp Force- busted skeg
take it to a welding shop that will do aluminum and let them have a look at it. a good shop can do it
bigbo
Depending on how it was sheared off, I would look into a product called Skegguard. It is made for this problem specifically or to prevent new skeg from damage. It is a stainless steel skeg that fits over the broken section, you drill two holes and through bolt. Very simple repair for under $100.
sony2001
It can be fixed fairly easily. $100 for the welder, $100 to remove and replace the foot. BUT afterwards check that the prop shaft turns straight. AND after running without any new foot vibrations check for water in the foot oil at least twice. PLUS the price of a prop! :cool:
