FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
how can you tell the top from the bottom when installing a fuel pump on a 9.9 force motor when trying to start motor getting to much gas to the spark plugs
Hmmm. Hi, Danfish.<br /><br />Don't know about the fuel pump. Guess that it will only go one way. If you are getting fuel to the carb it must be on right.<br /><br />Too much fuel when trying to start is a different matter. You might be overchoking it, but it is more likely that you have a stuck float in the carb.<br /><br />Good luck.
