I've recently rebuilt this motor and have good compression, no carbon build-up,and the timing is spot on. It accelerates cleanly and runs (loaded) at 4900-5100 RPM which is whats recommended. After a high speed run and return to idle,it stalls. It will start again only on high idle(not in gear)and runs poorly at 1000RPM for 15-30 sec. then revs up to 2300RPM like it should. After I get it cleaned out, it will idle roughly. As I suspected upon pulling the plugs, they were black,wet,and sooty. Can I(should I) rejet the single carb. slightly leaner to obtain the correct plug reading? I run factory specified Champions with a 50:1 ratio of 87octane "good" fuel and Stabil. The fuel filter and primer bulb are new also....
