1985 force outboard
lt.jim b.
I have a 85hp. 1985 force engine it run very good wide open for a shor time, I get a bearing spinning sound from the top of the engine, if i slow the engine down to 1/2 way the sound go away. I have ask people about it and say most engine have a oil line to the top bearing to oil it. I can not find one on this engine, is the bearing a seal type or is the oil lin in the engine houseing and do i need to chang the bearing.
lt.jim b.
Re: 1985 force outboard
If you have this type on engine bearing sound look at the gas system i have fix it, It was a low fule flow at hi speeds it reduce the fule supply to the top carb. and lean out the fule on this carb. only. the problum was a vacum leak in the fule change over vale. :)
