help me get going 85 force
mmirand5
i bought this 88 bayliner with a 85 force outboard. it has been sitting for 4 years. can anyone please help me on how i should go about in getting it started. should i replace the fuel,plugs, water pump, etc... all information will be appreciated. thanks
JB
Re: help me get going 85 force
Hi, Marco. Replace the water pump impeller. Completely purge your fuel system and clean everything: tank, hoses, primer bulb, fuel pump and carbs. <br /><br />Remove the spark plugs. Spray a bit of WD-40 into each cylinder. Turn it through by hand a few times. Clean and gap (or replace) your spark plugs. <br /><br />Try the starter, plugs out. Ensure that each plug is firing. Test compression on all cylinders; you should have over 100# on each, and less than 15# difference between the high and low compression cylinders.<br /><br />If everything passes to this point, mix up some 50:1 fuel with FRESH, 87 octane, lead and alcohol free gasoline and Wal-Mart Super Tech outboard oil. Pump the carbs full with the primer bulb, engage the choke and crank her up.<br /><br />If you haven't found it yet, this is where you may find a reason that the boat was put up for years and then sold cheap. OR, you may find that you got a great deal. Hope it's the latter.<br /><br />Red sky at night. . .<br />JB :)
mmirand5
thanks j.b.<br /> were can i find the parts for my bayliner? primer bulb, fuel pump, water pump, etc? online or only at dealers?
