Good evening,
My faithful FT-7100M stopped working, took it to a friend's house with an SWR/PWR meter; it's not moving the needles at all.
Removed my diamond mag-mount antenna base, removed the element, and tested mount/cable for continuity and it appears to be fine.
The antenna element (2m/440) has no continuity between the wire vertical element and the gold center pin inside the base of the antenna element... shouldn't there be continuity there?
There is continuity between the top part of the antenna and the bottom piece (separated by a hard black rubber piece). That doesn't seem right at all.
So, if I'm right about the antenna; I think this effected the radio.
I'm not sure what to do next to test it and figure out a repair.
Any help would be appreciated.
KRS
KRS
