Having done both, It is the same to pull a wakeboarder as a skiier--just a bit slower for the wakeboarder. Driver still needs to be observant of all conditions around him and needs to maintain a straight course and steady speed so the boarder can cut and trick. The same line skill, throttle skill, steering skill, and quick acceleration is needed to pull the boarder out without strain. A good driver will aid the boarder and make it look easy. A poor driver can exhaust and/or hurt both a skiier and a boarder.
Me? I hate to pop out behind my son. He means well, but sometimes doesn't think. He will pull me out on a turn, or with a slack line, and sometimes passes too close to other boats. Once, when I was down in the water, he almost hit me with the boat---WITH THE ENGINE IN GEAR! I cut him a new a**hole for that one.
It is no more difficult to learn to wakeboard than to slalom ski--Different but the same. After slalom skiing for over twenty years, I tried to wakeboard. Old habits die hard. It took me ten tries to get up and I was getting aggravated. Here I was, an expert skiier and I could not deepwater a wakeboard. Then when I finally realized a different set of skills was needed, I popped right out.
The thing is though, again, old habits die hard. The wakeboard does not have the big keel in the back. So: When I go to cut like on a slalom ski, in the drink I go. For that reason, right now I tend to be a little less aggressive on the board. More experience and I will probably go Balls-to-the-wall
Hey man any tips for pulling wakeboarders, im gonna be new to it this year and i'm sure a lot of people are gonna want me to pull them. obviously use common sense, but what about throttle techniques for starting, after that i'll pretty much do whatever the guy/girl being towed wants me to do.
Also to the op
s question.
1. no idea never towed either.
2. i guess i would have to say it depends on the person, i've done both and it took me a good 3 days to get up to ski. but when i tried wakeboarding and wakeskating being a long time skateboarder i popped out my first or 2nd try.
Find a place where you can run straight for a long period of time. Don't hammer the throttle at take off, like for skiing. Roll in to the throttle smoothly and only accelerate quickly after they come up. This is somethign you have to get a feel for on your boat with rider in tow.
Play with your trim to prodice a smooth wake with a nice peak, plan on running around 22-24mph, but this also depends on your boat. Run the boat around without a rider in tow with the approximate weight you expext to have in the boat when pulling a rider and play with your trim and speed until you have a nice form on your wake.
Once up and towing, small movements of the throttle will be needed from time to time. Finger thumb it, and resist using your wrist to move the throttle. Also, get a good mirror.
The stress put on the boat by an advanced slalom skier at 35 mph will be much greater than any wakeboard could ever produce. A serious slalom skier could test a towers strength any time.
To tow point for wakeboarding is high to help with lift. Skiers want to stay on the water... other tham a upward angle to help a beginner learn to get up... I don't see any othe advantage.
Resistance to motion by a fluid increase exponetially by speed. So a slalom skier making a hard cut around a bouey will pull more force than a wakeboarder, but get that ski at only 22mph and it won't. Though, I am not sure you can actually cut on a ski at 22mph.
