Re: diy ballast/fat sack ideas
I don't want to sound like a "no no" but you shouldn't use sand, rocks, anchors, lead weights, weight lifting weights, or anything solid, it's dangerous. Only use water. It's heavy, it's free, it's disposable. If you swamp your boat or take a wave, solid items like sand or wieghts will weigh down your boat and sink it further. If you swamp your boat with water ballast on board, the water has no net weight, since it's water floating in water. You can then simply pump it out or in an emergency take a knife to it and let it flow back into the lake.
Do a google search for Straight Line Launch Pad. They make 85 and 150 lbs fat sacs that are $25 and $40 each and come with nylon case, carrying handles and fill/drain ports. If you don't want to buy a pump, you can fill them up with a bucket and a funnel (buy a waterbed connector, a 2' piece of 1" PCV hose, two 1" hose camps, a wide mouth funnel, and find a 5 gallon bucket; connect the water bed connector, hose and funnel with the hose clamps and volia, instant fat sac filler. Take off the waterbed connector and you'll have a beer bong, bonus!). They are light enough that one burly dude or two girly girls can lift it over the side of the boat and dump it out in a few seconds. When not in use, roll 'em up and put 'em away, easy.
