I would be more concerned with how it handles an evasive maneuver and reacts under hard braking situations, than how it performs on the ramp.
Granted, if you have a bad ramp, it could be an issue.
I have towed many times with a 2016 Dodge Caravan, 3600# capacity, transmission cooler, and 290 hp.
Usually pull 1700#, occasionally 2300#, no problem.
Pulled 3300# one time because my buddy's truck broke, and we needed to get home from North Dakota.
It worked a bit on the hills, but I did not use the cruise, let her slow down up the hills rather than trying to maintain 55 or 65 mph.
I would not try to launch or load a 3000# boat with a front wheel drive vehicle.
ALL 3 OF THESE TRAILERS HAVE BRAKES.
Wouldn't think of it without brakes.
The first time going down a hill, or in town when someone enters the crosswalk will make you understand why.
Some manufacturers give a different tow capacity depending on how much weight you have in the vehicle.
And then there is the combined gross vehicle rating, which includes the tow vehicle, all its passengers and cargo, and the trailer.
READ pages 399-404 of your owners manual.
Also note on page 403, section on trailer brakes.
■ Trailer brakes
Recommended for any trailer with a total weight of 1,000 lbs or more
But disregard the info on electric brakes.
Electrics are fine on boat trailers, they will not short out.
