borntohunt1993
- Feb 22, 2010
- 79
I bought a 1998 Kawasaki 1100 ZXI not running. The owner said he thought it needed a starter or the bendix. After removing everything to get to the starter it was good and when you bump the starter it just sounds like its turning over but the motor doesnt. So I was told it was the bendix, I've removed the front motor cover to access the bendix and I can just wiggle it around but can't get it to clear the flywheel. Do you have to remove the flywheel to get the bendix out?? And if so how hard is this?? Mines pretty rusty! And how hard is it to re-install the flywheel?? Anyways I have this thing torn apart and NEED HELP fixing it before I have to put it back together and spend $$$ at a shop, any help will be greatly appreciated thanks!
