Welcome Guest - Sign Up today
No announcement yet.
please help me with a 96' wave venture 1100
  • please help me with a 96' wave venture 1100
    I am having problems with my 96' wave venture 1100. I bought it in august of last year. I used it for about 2 months. The day before it quit running, I had it out for about 5 hours. It ran great 61 mph at top speed. The very next day my brother took it out was gone for about an hour and called me to tell me he was dead in the water. The ski is running for a minute or two then dies out. It will run fine in the yard but when I put it under preassure in the water is when it seems to be givving me a problem. I was told that the wear ring is causing this. I have also been told that it is an engine problem. I just want to fix this myself and save as much as possible on repair cost. Can someone please help me on this issue. I can be reached at 910-742-1113
    Re: please help me with a 96' wave venture 1100
    We need a little more info
    You say it runs good in the yard are you putting water to through a flush line.
    Kinda sounds to me you are having cooling flow problems.
    First step would be to check compretion and spark.
    Then make sure fuel lines are in good shape.
    sigpic
    90 supra bravura pmc351 1.23/1 pmc40
    96 seaswirl squirt 115omc turbojet
    88 kawasaki sj550
    88 kawasaki x2 650
    92 yamaha waverunner III
    94 seadoo xp
    • #3
      When a ski runs fine on the trailer, but craps out under load in the water, that is typical for a bad engine. You most likely have either 1 bad cylinder or low compression on all. Do a compression check. Ideally you would want to see 120 psi in each. I'll bet you have at least 1 bad cylinder.
      2010 Hurricane 2100 Sundeck (217 SD)
      2008 Yamaha F150 TXR Outboard
      2008 Yamaha FXHO Cruiser Waverunner
