Welcome Guest - Sign Up today
No announcement yet.
1200 no spark
  • 1200 no spark
    hi my genesis has no spark it or has been tested for cdi and stator checked out bad so i replaced it i am now on my second stator from polaris and still no spark it has had every ignition part and wire have been looked over and tested and all checks out well any sugestions on what to do next.. anything would help
    Re: 1200 no spark
    Its an electrical problem. Start with the basics which means read your service Shop Manual. If the Battery is sulfated NO SPARK ect ect.
    • #3
      Re: 1200 no spark
      Make sure your ground cables are clean and tight.
      Sometimes the cables will corrode from the inside under the rubber coating. Esp the Neg cable if it sits close to the floor of the hull.
      I would remove the cable from the starter and pos from the solenoid .
      Put a light bulb type load on it and test the volts at the battery then test for volts at the end of the cable where you have the load connected. The volts should be the same. If not then the cable is bad.
      yacht....$1.8 million
      turnbuckle....$4
      expression of crane operator when turnbuckle broke and boat fell upside down in water....priceless
      True story in 2011.
