Welcome Guest - Sign Up today
No announcement yet.
Cleaning fuel system
  • Cleaning fuel system
    This is a copy and paste, original poster was Steach from http://www.greenhulk.net/forums/show...ystem-Cleaninghttp://www.mikuni.com/fs-carburetor.html
    Re: Cleaning fuel system
    Would not suggest using zip ties because this is a closed fuel system & it operates under pressure. In fact you must do a pressure test of the fuel system if you break any of the lines loose for any reason. Carb should also be completely rebuilt. There is more to it then what's stated here. Gas fumes are deadly if there is a leak in an enclosed compartment. A little bit of knowledge can get you hurt so get a manual & be safe when working on a boat/SeaDoo fuel system. You need to know what you're doing & the reasons why.
    sigpic
    People are like trees....
    Most provide great comfort, while some just occupy space & stunt the growth of others.
    Mercuiser 4.3L w/ Alpha Gen2 Drive
    Engine Serial #0M377480
    Sterndrive Serial #0M450311
