Re: Starting a Seadoo
In addition to what was written above, on a rotax engine, oil lubricates not only the intake (along the rotary valve), but also there is an oil bath that lubricates the bronze rotary gear in the middle of the crankshaft.
http://www.seadoosource.com/partspics/290886558.jpg
If the seals on either side of this rotary gear go bad, slip out of place, whatever, the oil will flow into the crankcase and into the cylinders. Upon startup, the craft will blow oil out the exhaust. The only way to fix it is to take the motor apart and reseat the seals or replace the crank. Its not easy to do and is a major PITA.
The oil flow is as follows.
The two small lines run from the oil pump to the injectors in the Rotary Valve Cover.
The three big lines are the feed to the pump, the feed to the Rotary Valve Shaft oil bath and the return from the RVS oil bath. The two feed lines come off the red fitting on the bottom of the oil tank (it does not matter which one). One will go to the oil pump and the other to a fitting just below the oil pump.
The return line for the RVS oil bath comes from under the pipe and goes into the top of the tank where the breather check valve is.
