Finally found a merc. for my 96 Sea Pro Reanergade , it in a 95 Sea Rader, the Sea Pro had a 120hp merc. the Sea Rader has a 90hp. Before I take it out I'de like to start it. But the key switch is messed up. There are two 6 pin plugs at the steering wheel, one goes to the key switch witch also has the safty cut off, there are a couple cut. The other does'nt plug to anything that i can see. The boat has no gauges just a blank panel where they should go. What I'de like to do if possable is bypass the key and safty switch (cut the harness at the steering wheel) try to wire where I can touch wires together (hot wire) it. Does any one have a clue witch wires need to be hooked to witch or have a wiring diagram for a 1995
SeaRay Rader with 90hp merc. Any help would be great.
thnx, CBazzle
thnx, CBazzle
