1996 F16 sea rayder--what to do--no compression
CWK1958
I have a 1996 F16 Sea Rayder 120 HP engine. The boat never ran right nor started easily. Mechanic evaluated at said it has low compression in all four cylinders. about 60-70. Needs a starter and some other things.
The boat itself exterior is in excellent condition.
What do I do about the engine? I am waiting on an estimate to rebuild the engine. The boat itself even it was in working order isn't worth too much. So after the estimate (which I am assuming won't be cheap) do I just put it out to jetboat pasture and look for a true small boat.
If the engine is rebuilt, would I encounter the same issues again, ie don't reach top speeds, starting etc.
Any thoughts would be appreciated.
Regards,
F16 Jet Boat Owner
ryanr623
Re: 1996 F16 sea rayder--what to do--no compression
Regards,
F16 Jet Boat Owner
No with proper compresion (more than double what you have now) you should run top speed. I don't know if you are mechanically enclined but changing the pistons on a 2-stroke is very easy. I did it when i was a teen and had zero knowledge about engines. Theres no cams, valves, throttle bodies, injectors, etc like on 4 strokes. They are a jug, case and head. If you know someone who is even remotely mechanically inclined you guys could rebuild it yourself.
BTW after a couple times changing pistons, i could disassemble and assemble a 2-stroke in less than a day.
