gustafsonerik
- Jun 25, 2006
- 238
93 yamaha 650 it sat two years i bought it put a new starter on it and ran it.. While running about a hour the overheat system kicked in..I shut it down cleared the shaft and ran it..30 minutes later it happened again this time it wouldn't start after i cleared the shaft..I thought i fried it..I took it home and this is what i found/.. compression is good 150 and 149..One spark plug was soaked with oil and the other looked like it had lithiium grease on it..I did find out that the gas i used had 50:1 oil in it..that plus the oil injection would that do that??? what should i do now..Should i change the fuel pump diaphram??? back flush it??clean the carb what's next PLEASE ANYONE"S ADVICE IS GOOD thanks Erik
