haulnazz15
- Mar 9, 2009
- 3,720
Trying to get the WOT rpms up to spec, but not sure if it is a prop/drive limitation or engine issue. Engine runs flawlessly up to this point. Drive has been trimmed up until max rpms/speed is attained. Max rpms per Mercruiser should be around 3800-4200. While this is the same prop that has been on this boat for over 20 years, we didn't recall what the WOT speed/rpms were before repowering. The old engine was the 233HP 351w, so the only major change was a 4bbl carb. Is the 15 1/4" diameter a bit much to swing for this runabout? Looking to see if maybe dropping a tad in the diameter and running a 17/19 pitch would be a better fit. Prop slip calculators put my numbers in the 11-13% slip range, so it doesn't appear the numbers are out of whack.
1) WOT RPMS are ~3200
2) Michigan Wheel SS
3) 15 1/4 x 21
4) 3200RPM @ pitot-measured 42mph
5) Mercruiser 233 (1.32 ratio) 351w w/4bbl carb ~ 265HP. New engine, less than 15 hrs time.
6) 1976 Mark Twain 200VBR. 20' - guessing 3000lbs.
3) 15 1/4 x 21
