TunaFish389
- Apr 26, 2018
- 184
Boats a 1984 Ebko v165 16.5' with Mericruiser 3.0 and Alpha One Gen 1 drive. Currently have a Solas 14.5" 17p four blade prop. Running 25.5mph at 3600rpm at cruise and 33mph at 4600rpm at wot with usual load. I would like to lower my cruising rpms while keeping my speed.
I am thinking of going to a three blade prop (Solas) but not sure what effect that will have on my prop slip. If the three blade will have more slip then a prop change might be out of the question. If the slip is unchanged then I could cruise 26mph at 3300rpm with a 14.5" 19p three blade which would be idea.
I am guessing I would go down 300rpm on the top end; minus 400rpm going up two pitches and plus 100rpm losing a blade. This will in theory keep me in my max rpm range and might gain a mph on top but not to worried about top speed.
What do you all think/suggest? Thanks.
