I have a 1984 trophy 1910 CC with a same year 125 force outboard, the prop that's on it is a 13-1/4 x 17 Michigan SS prop, (has Coligan stamped on the side) the boat struggles to get on plane (best result is moving passengers to the bow, but still doesn't feel like getting full power) and the engine is only getting to about 3200-3500 rpms at WOT, Speedometer is reading about 26-32 mph.
Engine tag has 125hp @ 5500 rpms and operating range between 4500 to 5500. Got 150 psi on all 4 cylinders, engine runs really good, starts right up and idles at around 7-800 rpms.
So, I'm not sure if the prop that's on it is the original factory? or previous owner changed it out? I believe the boat is suppose to weigh around 2100 lbs empty, it has a 40 gal. gas tank and the sticker says it's a 5 passenger max boat capacity. as you can see there's a lot of question marks ......help!!
