This year I changed the propeller and hub on my 1997 Maxum 2300 Powerboat (Merc 5.7L Alpha 1 Gen 2) and now I have a 10% decrease in top speed at WOT.
I understand that the different diameter and pitch of propellers can change top speed and acceleration, etc, but my problem is that I replaced my existing propeller with a brand new propeller of the same dimensions.
Previously I had a 15.25 x 15 Aluminum 3 blade prop (which was probably the original with mercruiser drive) I replaced it with Michigan Wheel 3 Blade Aluminum Propeller 4-3/4" Gearcase 202 Hub Kit
(Size: 15 Pitch 15-1/4" Diameter) for $133 online
With the old prop, my top speed in ideal conditions, half a tank of fuel 2 passengers, smooth water, etc is 37mph at 4700rpm at WOT
With the new prop, my top speed in ideal conditions, half a tank of fuel 2 passengers, smooth water, etc is 33mph at 4700rpm at WOT
This week I reverted back to the old (original) prop which is dinged up and missing a few chunks, and it still performed at 33mph at cruise at 4100rpm.
My question is, why is the new prop NOT performing the same and not better than the old prop?
Could the hub make a difference? I had the newer slotted design on the new on vs the old on the original.
Could the aluminum be cheap and substandard and losing integrity at high speeds?
Could I have over tightened the new one?
How do I get my extra 10% off performance back?! Thanks!
