rstreb3829
- Sep 25, 2015
- 2
I have a 1965 Johnson 6 HP Model CD-22M Outboard Motor that is missing the prop. Does anyone have a good number or source for this? I have ordered several and they are not correct. This application has the shear pin under the prop nut at the end of the shaft. The shaft is 0.555" in diameter. Later models have the shear pin UNDER the prop.
