Hello -
Just ordered a new solas 9.9x13 prop for my Honda BF30 and found that neither of my thrust washers (identical) fit inside the hub assembly of the prop as they do with my Honda prop and another unmarked prop. I still have enough threads to bolt it on fine but am worried if there might be alignment issues. No issues with the spines etc and the washer is inserted the correct way.
I've read of people pounding them in but am not sure it would fit and am a bit worried about deforming something.
Silas only lists one thrust washer for this motor and I thought they made Honda's props so I'm a bit confused. The box does say Yamaha but I believe the props are the same.
Any ideas?
Any ideas?
