nice-diver
- Sep 10, 2007
- 42
hi
I have a 1997 Zodiac mk3 GR
It used to have a jet drive on it that used a raised...laminated transom plate.
When the long shaft johnson 40 was installed the cavitation plate measures two inches above the bottom edge of the transom.
my problem: if the boat gets on a plane it cavitates and looses bite. the prop moves water, but not the boat.
my question: what is the measurement difference between the lower transom edge and the lower edge of the cavitation plate.
I will trim the aluminum laminated plate shorter to lower the motor to the proper height
thank you
thank you
