Hi guys, just purchased a Intex Excursion 5 and seen the videos on a solid base, will be attempting that at the weekend , what i need to know is if anyone has a rough idea how long this set up would last (ie how long i could use it on the water before battery needs charging) - not hot on working that kind of thing out
I have a 110ah lUCUS LX31 Leisure battery and will be using the Rhino Cobold vx18 trolling motor
Battery says 110 ampere hours
motor says weight 2.45kg
speeds 2v/2r
if any of that helps, i do have a 10w solar panel so suppose can always connect that as well so trickle charges it as such
Cheer guys
speeds 2v/2r
Cheer guys
