Where to find windshield support
SteveRay
I have a 92 Searay Bowrider. One of the pole mounts on my windshield is broken. <br />Anyone know where to find a replacement?<br />Only thing inscribed on the windshield is "taylor made"<br />Thanks guys
SteveRay
Re: Where to find windshield support
Yes Sir........You da man
Eggkr8
Taylor made is still in business. I would just contact them directly
mikeneal
Yup, I bought the plastic end pieces for my taylor made winshield support.
lakelivin
Originally posted by Mike Neal:<br /> Yup, I bought the plastic end pieces for my taylor made winshield support.
Mile, where did you buy just the plastic end pieces and how much were they? Are they the type that articulate in all directions?<br /><br />I needed some years ago, couldn't find em, and rigged something up using an articulating support (one directional movement) designed for something else. I had to get new aluminum poles & cut to size. It works, but the end pieces are a bit bulkier and not quite as smooth looking as the original. Might be worth redoing if cheap enough.
Capn Mike
Good luck on contacting TaylorMade....I've sent them 7 or 8 emails plus a phone call, and have yet to have anyone answer back....
i work at taylor made, let me know what you need.
What ,..!!...... We Need to talk.........<br /><br />Please drop me a line at .....
lakelivin
Originally posted by sandwichestime:<br /> i work at taylor made, let me know what you need.
I was looking for just the plastic end attachment pieces for older windshield support tubes (the ball & socket type that articulate in every direction). Are those available without purchasing the entire support bar?
are they available to just anybody? i would assume so, but we just cut our windshield stanchions to the engineers original specifications and bolt those end pieces on. now, i myself personally have only worked with the stainless steel ones, but i could look for some plastic ones for you if you'd like me to, let me know.<br /><br />
Originally posted by Bondo:<br />What ,..!!...... We Need to talk.........<br /><br />Please drop me a line at bbondo :at: gmail.com.....
just drop me a line at wonderllama@hotmail.com <br /><br />ill help out with what i can
SteveRay
I see these available in Overton's, Boaters World, Here on Iboats, and they are available in different lengths. <br />My question is "where do you measure from?" The entire piece or just the pole length?<br /><br />Also I would like to replace my plastic ones with Stainless where could I find these?
