Re: Smart Tabs on my Bass Boat
When I mounted mine, I used the double stick foam tape from 3m. Itallowed me to stick the tabs to the boat while I drilled the holes, mae the installation very easy. I also used a sealer around the screws when I put them in.<br /><br />rnsi, your are right, our boats are very similar, Can you even imagine the boat is even the same boat? I get flack from other bass boaters at the ramp about them. Such as, "Why do you have them things on there"? "If you have to have them then something must be wrong with your boat"><br /><br />I actuall got into such an argument with one guy, I had to put my boat back into the water and blow him out of the water.<br /><br />I was so far ahead of him by the time he even got onto plane, that he couldnt have caught me even if the lake was bigger, he had a 175 HP on a 19' boat and I kicked his but bad. He then wanted to talk. I loved it. He accused me of having a 175 or 200 under the cover.
