1960Aerocraft
- Jun 6, 2010
- 2
I have a problem with a fresh water pump that is really baffling me.
If I take it out and hook to a battery it will run. When I plug it back into the socket on the boat it doesnt run. I have checked all the wiring, checked for voltage at the wiring, which is about 11 volts. If it isnt plugged in and I flip the water system switch on, I will get the little light on the panel which says that it is on. I then plug the water pump in and the light goes out. I have the polarity correct and just dont know why it wont work when plugged in. Any ideas? It is a shurflo pump
Thanks in advance
Thanks in advance
