Welcome Guest - Sign Up today
No announcement yet.
Need Sealant for Mounting a bimini?
  • Need Sealant for Mounting a bimini?
    I was reading through a few posts and saw some people mentioned using some 3M sealant for when they mounted some hardware. I read through my instructions when I installed the bimini and there was no mention of this. Should I have used sealant on the screws? Also if I should have is it to late?
    Thanks,
    Hostage
    2000 Maxum 1900SC
    4.3L Mercrusier w/ Alpha One Gen II
    Re: Need Sealant for Mounting a bimini?
    I doubt there's any sealant or glue required or recommended for mounting a Bimini top, just the hardware and screws. I might use sealants like 3M or silicone for mounting below water line or where I'm trying to waterproof the mountings. I used a bit of silicone on my fishfinder mounting bracket on top of my console just to keep the rainwater from leaking down underneath.
    • #3
      It really wouldn't have been a bad idea to use a sealant.
      above waterline - 3M 4200
      below waterline - 3M 5200
      • #4
        For hardware that doesn't matter if it's water tight, a little silicon won't hurt. But a few tiny droplets around the bimini fittings won't do any harm to anything, practically speaking. But if you put some permanent bond in there you may have trouble if you have to replace the fitting or want to move it--and that is far more likely than needing to keep out the droplets.
        A man of constant boat tinkering.
