Gas tank sources
79Glastron
I'm looking for new gas tanks for my V-212. It has two 18 gallon tanks under the forward and rearward facing seats sitting on the floor. I've seen a few tanks that might work but they all seem to have a straight fill port, I'd like to have one with a 90 bent so the hose doesn't have to flex so much.
Thanks
mpsyamaha
Re: Gas tank sources
or maybe you could just use a 90 degree fitting on the tank, depending on design.
tommays
I bought Trident Corrugated 1-1/2 fill hose as at can really take a tight bend without issue
I had to have a tank built as nothing would fit off the shelf which was a lot of money BUT i feel much better about the install
Tom,.... Looong time No See,.... Glad to see ya Back,....;)
79Glastron
Looks like the Moeller # 032519 will work. Are these tanks good quality?
Thanks
seabob4
Yes. Moeller and Inca are the primary suppliers of roto-molded polyethylene tanks to the builders...
