I had posted this in the "Whaler" forum with no response, so I am submitting it here also.
I have had this boat for about two years now. It is 18' long and has "Boston Whaler" logos on the sides. The CA registration lists it as a 1976 Boston Whaler. It has a foam filled double hull, however, the shape of the front flares and the finish is different than other Whalers I have seen. The transom has "18UB7632" cast into the stern face. It has a heavy steel or aluminum rim/rub rail all around the top edge of the hull. Any ideas? Boston Barge?
